Topic: "O" sized drill bit (Read 1157 times) previous topic - next topic
  • 522
"O" sized drill bit
any leads on where to buy an "o" sized drill bit that isnt a million bucks?
i need one to drill out my flywheel for 8 dowel
thanks
1971 Super Beetle
  • RotorMan
  • Full Member
  • 174
Re: "O" sized drill bit
I have an 8 dowel stencil plate you can use
Dusty D.
'67 Ragtop
  • 2,075
As precise as that needs to be it might be good just to have a machine shop do it.  Steve's Machine in Tigard would probably do it.
  • 522
Thanks...I have the plate.  Its the drill bit that is impossible to find for a resonable amount.
Ill check steves Mark...thanks.
1971 Super Beetle
  • 522
by regular do you mean 8mm?  The specs I have seen is that the O size is 1 thousandth off of 8mm
1971 Super Beetle
