Topic: Revs 71 (Read 82238 times) previous topic - next topic
Re: Revs 71
Reply #75
Thats c-box.  I would stack gaskets...but I'm running an electric pump.  I will have to check into the holley regulator.
Is this the one your talking about.....
  • 1,151
Re: Revs 71
Reply #76
i used and liked this one
http://www.thesamba.com/vw/classifieds/detail.php?id=1186375
same one AJ Sims recommends and uses  :2up:
Re: Revs 71
Reply #77
do you know the maker/model for this?
  • CatBox
  • 4,200
Re: Revs 71
Reply #78
Yes the Holley looks correct.
You just want to make sure it is the low pressure version, as the regular version is for the larger V-8's and such.
  • 1,151
Re: Revs 71
Reply #79
no call AJ at www.lowbugget.com
  • Kev
  • 1,573
Re: Revs 71
Reply #80
AJ Simms is sadly a major failure in the customer service area. Just read the reviews on the Samba about him.
"Our Faster is Faster than their Faster" as seen on a local motorcycle company truck...
  • 1,151
Re: Revs 71
Reply #81
this is very true sorry  :lame:
Re: Revs 71
Reply #82
Well,
I was inspired after donuts to work on the super....got er running....I think I have a fan shroud knock, either that or exhaust against the fender.....as long as its not internal Im inclined to to care too much.  Onward on more toward a drivable vw!
Re: Revs 71
Reply #83
Here is the verdict on my motor....The gland nut came loose so the flywheel was flopping around in the bell housing...It wobbled out the pin holes in both the crank and the flywheel.  Thankfully, all I have to replace is the flywheel, the crank, and the mains....should be ok I think after that....Oddly enough I found that I have an 8 doweled lightened flywheel in my stash as I was looking for spare parts...fun day!
Re: Revs 71
Reply #84
yay another 71 super!!! i has one to , tho i need my morot rebuilt (leaking oil like a siv and not running
Re: Revs 71
Reply #85
i hear you Silvie....I've been workin on this car since October '10
Re: Revs 71
Reply #86
ya but our is my mate main transit and we just got it so it being dead is not good
Re: Revs 71
Reply #87
This was my daily until my 1641 spun a bearing....it has not been replaced either.
Re: Revs 71
Reply #88
awww that sux... maybe we should all have a super day xD just rebuild all the motors Assembly line style xD :beat_deadhorse: then have a nice big bbq dinner (i love to cook)
  • Last Edit: January 16, 2012, 08:48:57 PM by silviefox
Re: Revs 71
Reply #89
Since last Friday...engine out...problem diagnosed...engine torn down to nothing...bearings replaced, crank replaced, flywheel replaced, gland nut replaced....engine reassembled and back in the car...time to static time and start er up.
